  • Replies 21
Zubat is curved and therefore can't produce the same cut as a Gomtaro. Again they are two different types of saw with a different blade for different types of cutting.
i dont care which as long as its sharp! quite like the hook on the end of the sugoi though. as rob said about the small stuff though but i sometimes just snap ends off with my chunky thumbs
Each Silky Saw is designed for particular types of cutting,wether is close quarter small diameter stuff or larger diameter with more aggressive tooth settings producing faster cutting Action.Thinner blades great for filleting or tight area cutting. Flat blades for precision cuts or curved blades particularly useful for shoulder height or above. Most are available with a variety of blade length and tooth size. There are many videos on YouTube reviewing there different characteristics.
I like the Zubat if you're going to sever the wood. But for hedging, where you might want the cuts to come together neatly, the Gomtaro with its straight blade has the edge.
