Oil fired central heating..anyone?
pie eater pete
  • Replies 24
Used to have one. Mine was a converted Rayburn so it warmed the house, did the hot water and you could cook on it.
The challenge was that if you let it go out - summer, out of oil etc - then it would take 3 days to get it back up to running temperature. And as it's a conversion, nothing seemed to fit correctly so once a year, the cracks would be cemented. Nearly lost a dog through the fumes.
But otherwise, once you're on it, it's only the price of oil that you need to worry about. although I hear you can put cheaper alternatives in the tank - google it.
Is it just a normal combi boiler? If so, in my experience (18 months only) it's no different to our gas boiler at the old house other than it runs on oil. Still needs the same maintenance that you'd do on a gas one (or not as the case may be). Price of oil is a consideration and the fact that you can now decide when to buy if you have a big enough tank to leave space for when it's cheap(er). We only have a 1000 litre tank so we fill up, use it then fill again. If it's near enough empty we have to buy regardless of the price. Given we're in rural location most heating engineers anywhere near us are oil certified. That may not be the case though if you're in an area predominantly covered by gas though.
I'm just waiting for the paperwork to be sorted then we will move in to our "new" place, & this will be our first oil fired system, as there's no gas in the village. Apparently there's a scheme where you can get together with others & buy your oil in bulk there by saving a few £'s.
Rob
I've lived in many a property that's had oil fired central heating. Never had any problems whatsoever with it.
There are, as Rob (dogman) states oil cooperatives whereby members buy oil in bulk as buying over a thousand litres reduces the cost compared to buying 900 litres.
There are also various schemes that oil fuel companies offer, most also can provide you with a plug in device that lets you know just how much oil you have in the tank.
One thing I found was filling the tank in summer was cheaper than autumn or winter.
Rob
Yes, Boilerjuice do this (others may too I'm not sure). We have a DD with them as well.
Only major difference between oil and gas in my experience is oil is marginally more expensive and you have to take hit of filling tank in one go.
My current system is oil boiler outside coupled with boiler stove inside and accumalator tank in attic. Both systems work well on their own though usually I have stove on so use very little oil.
