Right decisions decisions,
Yellow jackets 208 + vat and keep std wheel
Multi tip 395 + vat
Hmmmm been told the yellow jackets are really good... hmm
  • Replies 37
I've ordered yellow jacket teeth n pockets as needed clutch too!
How many to put on the wheel? Theyre sending 16 pockets and teeth so 8 pairs, same as current setup.
If i run with less, will it be any better or faster?
Cheers
its a bit of a debate as to less teeth work better or not the theory is less teeth taking a bigger bite look at the green wheel on youtube and why the multi tip works well less teeth this also works out cheaper as well
I use proteeth because we can use a diamond disc in an angle grinder to sharpen them whilst the teeth are in situ. If you don't blunt them too much then it take around 7 minutes to sharpen them.
We also have a 1000w power converter from the truck battery and a very long extension lead for when clients are not in. I brought 3 diamond discs about 2 years ago from abtec for around 50 and they don't really wear out.
I do not work for this company but I said I would post his details here:
I brought copies of vermeer proteeth (he has other brands/copies)from this guy called Glyn at
http://www.qrmslimited.com/products-and-spares/stump-grinder
Err at almost half price, very nice guy very good service.
Those pro teeth are currently whats on. Cheap via that link but pita to change with having to remove pocket etc?... Not sure weather to keep them when removed or throw
you dont need to remove the pocket just loosen it ,then tap them with a hammer to free them, if there bad to get out the pockets may be nackerd & nipping the shafts ,
Right... anyhow ive changed the system, waiting n the courier :D
Bish bash bosh
Does anyone know the torque for the pockets on these yellow jackets? Also the torque for tightening the tooth to the pocket?
I asked vermeer to send me them but they must have forgotten :(
