  • Replies 160
They are great, almost enough to rival 70cc saws! I have plans for the new year to see what they can really do, the high-top will give an extra dimension to my plan (I'd never given it thought until now).
HI EDDY will a 560xp then out power 372xp your saying thanks jon :thumbup:
Up to 18" yes, as it has a higher rpm range, after that, torque take precedence on big bars.
Ian, I have ported my 560, but I have to wait until next Monday to get the 562 air filter, I'm also trying to sort out the muffler, as I can't weld, so a third party has to do it for me.
The black frame filter is 80 micron ( winter filter ) and should not be used on dusty timber, the tellow filter is 44 micron and should be used in the UK, the smaller the micron size the greater the filtering capacity
cant see how it will make more difference, i just got a black nylon filter for my 560 when working on some dusty sites in summer and compared to the yellow one didnt notice any difference at all
Increased airflow, using the black filter in summer will cause damage to the engine as it will suck more dust through
HI EDDY so how do you port AUTO TUNE saw do you have to remap it thanks jon :thumbup:
You can't "remap" the autotune, all you can do is let the autotune do its business and hope that it can cope with the porting within its operating paramaters!
HI STEVE can you not remap it then hows it going no when you port it hows it going to no this thanks jon :thumbup:
The autotune runs off rpm, so if the limiter is activated it adds more fuel, if it doesn't reach max rpm, it adds less fuel, it's a very simple process! If you wanted to 'remap' the saw, you'd have to delimit the coil first
