  • Replies 39
You definately need a waterproof membrane
Guys who put my shed up 'forgot' to do it
It was a massive job to get it in afterwards
Not surecabout your choice of membrane they make stuff for the job
But others on here will know exactly what you want
Tyvek?
You want a breathable membrane rather than waterproof - doesn't let rain in but lets vapour out, to reduce condensation and prevent trapped water between the membrane and the wood where it contacts, leading to rot.
I am using Cromar Vent 3 - the Original is the heaviest duty one. You can get some decent deals on this on Ebay.
Alec
Good quality cladding and decent ventilation, then membrane is not so vital, if pennies are not an issue you can pay a lot for it!
Your local builders merchant will probably stock Tyvek and a cheaper version.
Tyvek is the Rolls Royce of breathable membranes. For a shed I'd look at cheaper types.
One roll of tyvek will do one side of an average sized house roof as there's quite a lot on a roll.
Alternatively, chat up your local roofing company and see if they'll sell you a length (measure what you need firstly!)
codlasher
We have Tyvek breather membrane in the roof of our house, seems to be good stuff and I'm thinking of using it for our timber barn. Cheers, Steve
Jamesd, previous comments are correct; you don’t need a waterproof barrier behind well-designed timber cladding (unless its a partial rain-screen type cladding). The product you identify is probably not a good idea for your shed.
A vapour permeable membrane ('breather membrane') will reduce air-filtration /draughts if heat gain or loss is your concern. As others indicate, that’s a better option. But even so called breather membranes are not always a good thing.
Photo show condensation-related mould growth in a traditional roof construction where a high-quality 'breather membrane' has been used. You can see the grey mould and if you look carefully you'll see the condensate droplets too.
Effective building is more about the way you use materials rather than the materials themselves.
Interesting, which make of membrane is that? Cheers, Steve
Read more
