Tw 150 roller motor
swinny
  • 5 months later...
Right ive had the machine stripped down for the last month or so! A guy at timberwolf says yes you can buy seal kits.
Mines an old eaton motor, motor works fine, no play, shaft seems ok so new seals should work.
All i require is x 2 seals and a brass washer/ shim and we are up and running again.
Timberwolf technical waste of time with this say can only fit new motor
Parta department today said they dont do them, cant order them either. Have to buy a new motor at 240.00 inc vat...
Thats crap if so! All for 2 seals.
Anyone else had any luck doing this?
find a hydrualic pipe fiter they will have them in stock, or graham fawcett @ bentham
