Hello,
I currently have a Stihl 038 & 064 both with 20" bars. As they are getting on a bit I am thinking of changing to a modern saw. I have just had a new clutch in the 064.
I buy timber by the trailer load and currently have about 50 ton to log up, size range from 5" upto 30".
There is 2 of us that work together, cut into 40" lengths then split then cut on a saw bench.
Looking for something to cut quicker than my current saws, I have only ever had Stihl's but would contemplate a Husqvarna, my short list is made up of MS362, 440, 441 or 555, 357, 372xp
Thought about a 560xp but I am not sure about all of the "High Tech" on it.
I just want a good reliable saw that is lighter than the 064 as that seems to be the saw I pick up first, possibly thinking bigger saws cut quicker which I know isn't always the case.
What are your suggestions?
Thank you Andrew
Edited by arhfirewood
Additional model added
  • Replies 21
How about an MS461 ? I use my 046 with a 30 inch bar from time to time, a reasonably powerful saw and not too heavy and great for ringing up firewood. The 046/460/461 saws all seem to be generally well liked by their users.
Hi log that's a good saw mate the 461 I have my one on a 20ins bar mate thanks Jon
When you said up to 30" I was thinking Husqvarna 390/372 . a bit of weight but if just cross cutting then not so much of a problem . Depends on the ratio of small stuff to big and do you put the small stuff in a horse of some description so cutting in bundles ? I think 372 could run 15" bar up to 24" bar .
Thank you for your replies.
There isn't much 30" wood and most can be cut in 1 pass with a 20" bar, it is also just cut where it is tipped and the small stuff isn't bundled. Only buy hardwood loads.
I was thinking as I have just spent some money on the 064 I would keep this saw for any big stuff as it isn't very often, and then get something lighter and faster with perhaps an 16"/18" bar to replace the 038.
Something lighter and faster would be Husqvarna 560XP . I run mine on an 18" bar .325 driven by an 8 pin sprocket . Easely converted to 3/8 though if you wanted to keep the same pitch as the bigger saw . ( Same files ) :001_smile:
