A decent chain, Boron/steel, will stop the opportunists. The, rather long and not working, link was for extreme metal cutting reciprocating saw blades, which, at $560 each, one would expect to make short work of most things.
It's what they used on us, so the police said.
  • Replies 47
Frightening bit of kit Paul.
That or hot gear and they could take the RSJ.
The 1mm grinding disc is also a worry, but at least saws and grinders are noisy.
Christmas is coming (sorry, I don't believe in mentioning it before mid November), and the bastards always seem more active in the lead-up.
battery grinder and 1mm sliting discs are quicker than a key these days, more rather than bigger and stronger,
Unfortunately this is so true.
its a pity you couldn't get carbide coated chain theres nothing you can do to prevent them now you can only make it noisier and more hassle to nick your kit then they go and take some other poor buggers gear that isn't so well protected
