I work for a large nursery and we need to remove about 20 large leylandii. They are up to 36 inches at the base. We have a ms181 that we use for general hedge maintenance pruning etc but a bigger saw is needed for these trees. What saws would you recommend bearing in mind this is a one off job. Most cutting at height can be done from a telehandler cage so I think we can manage without a top handle but I am open to suggestions. Rather than risk secondhand we normally new equipment.
  • Replies 48
As above, or consider a Husqvarna 365 with 20" bar for similar price.
Take care cutting stuff that size from telehandler, especially if you're not used to it :)
Not a problem I shall be firmly sat in the telehandler seat. Should be safe there.
Seriously though we have an experienced tree climber on staff so he will be doing the cutting. Appreciate your concern though, I know leylandii can be pigs.
Edited by cornish wood burner
Being in drivers seat is the worst place if large stuff is being cut.
What are the main pitfalls to cutting large Leylandii?
What Steve said about the 560 18" or go American style and strait in with the 395 36" Depends , can you fell em strait on to the ground ? or do they need climbing ?
