I'm modifying a truck for work, and just have the chip box to build.
I'm thinking of making a steel frame and want to board it on the inside.
The last prototype I made used stockboard, which is an agricultural recycled plastic alternative to timber plywood, and comes in the same sizes, 9mm, 12mm and 18mm. The trouble is, it swells in the heat and goes all wavy, and doesn't shrink back to its original size.
I'm looking for an alternative, synthetic, water proof product that will do the same job. I wonder what tipmaster and the like use?
Any suggestions gratefully received. Thanks in advance. :thumbup1:
thanks for the replies. GRP sounds like the answer. Does anybody know where I can get some from? Can't find any on Google, I'm just getting ferry boarding times and patterned grp boards for bathrooms!
Try service metals, they have ally and GRP
Service Metals
For light as can be but not very strong try aluminium composite panel (ACP) which is more plastic than aluminium and will need a better frame than others.
Its OK for a chip box but logs will kill it in no time at all.
We have GRP sides. Heavy but hard wearing and look tidy. As someone else surggested I think the cheapest way is to buy any old box body and cut sheets from it.
