side cover removal and exhaust removal takes about 3 minutes.
wonder if cutting open the zorst and removing the offending loose part and placing it in the thrash receptacle would cause any running issues ie; would it run lean as a result and cause enjun damage? suppose ya cud simply tune it. Bet the warranty would be null and void then.
Yeah I was thinking just take the baffle out and richen it a bit
hi all bit of a disapointment with my 360 tes after 3 weeks it has not sorted its self out as hoped . after cutting a limb it runs on and chain goes round . no amount of tuning with the high and low needles or tickover screw can dial this out , fine if just free reving it but not once used under load . anyone had probs with their 360 like this . its had to go to the shop they are going to sonic clean the carb . shame as our two cs620sx saws are going well .
not had those probs. thank goodness.
I was told today that echo spares are a lot more expensive (though hopefully not required so often) - an example was a clutch drum costing nearly £40 while the Stihl ones are around £11-15.
My dealer sells mostly Stihl and Husky but he can get hold of Echo if needed so he's not entirely biased.
Just another consideration.
C'mon Echo, good product - seize the moment and get spares (supply and price) sorted.
I'm still undecided.
Looking to buy a new top handle saw just not sure whether to get the echo or the husky. Have used a husky a few times and felt powerful but have heard about some probs with it. The echo is a lot cheaper and I have a small echo top handle which is good but don't know what the 360tes is like?
I have the 360 TES also, i too would buy anudder one if required but it's a toss up between a new MS201T as they are excellent imho.
