Anyone successfully done a 'de-cat' on an Echo 360 TES / WES ? Reason i ask is i have a spare exhaust with the loose baffle/cat and it's rattling around on me work bench.
I managed to break out the core of the cat with a hammer and screw driver (as it's ceramic type material) but i have yet to successfully remove the remaining steel ring surround from inside the exhaust.
When i do i may try it out and see what the performance is like.
That will be interestin, bet it will need a carb adjust to run well.
post results if you will. :001_smile:
got my 360tes back from carrs billington today after carb strip and sonic clean then tune up . pleased to say it now runs great no more cutting out even after ticking over for 10 mins today and no more running on after cutting . thanks lads . i will add our 2 620sx saws have been excellent 1 of them has now cut over 1500 tons needing only a pull cord not bad at all
  • 2 months later...
just ordered one from here
£270 including delivery at that price had to have one! i'll let you know if it never turns up etc
Same company I got my 360TES from. Took a week to arrive, no PDI but ran fine straight out the box.
So they do, fancy the newer one though, that or the ms150, but a £250 price point would swing it
yep i too was hoping to find the new CS2510T fer under £300 but alas no.
