  • Replies 30
I brought the impacto ones from severnside saftey and the work well on the hedge trimmers ( got an old stihl hs85) there protected on palms and inbetween thumb and finger.
does anyone use them and if so what makes do you prefer, thinking of getting a pair for hedge cutting and using the blower.
the timberland ones are excellent, under 30quid i think:001_smile:
I did some research recently on havs for our upcoming health and safety audit, from what i found out there is no proof that anti-vibe gloves provide suffcient control measure for reducing vibration. Basically it may feel more comfortable but you'll still need to take regular breaks and not be able to use any power tool for a longer period just because you are using av gloves, i'e they offer no usefull protection.
I don't remember where the document is, i've looked at so much info my mind is a mess, but in can be found on the aie website.
I was given a pair of Dewalt glloves with big pads on the palms and fingers which seemed to make a difference- on cold days i didnt lose the sensation in the tips of my fingers driving home after using them, but the didnt stand up to cerious abuse tho. (granite!)
I've used both, and the timberland fingerless gloves lasted much longer. i think that they do reduce the amount of vibration because when my dog decided to eat one for his lunch, and i had the rest of the afternoon with only one glove, and i could feel the difference.
Slack ma girdle
i can spot a tree from 100 yards
could that just not be down to the extra insulation the padding gave rather than the reduced vibration, after all thats why saws have heated handle.
reduce the vibration on the tool
new bg86 has full vib mounts that according to statistics can be used 24hrs per day without risk of HAVS
the old blower bg85 was really bad on vibration
stihl,s new range of hedge trimmers are really low as well compared to the others
the problem with vib gloves is they ate like trying to hold something with layers of bubble wrap wrapped around your hands so you have to grip tighter so the beniffits are less
replace kit as they are always striving to improve stuff
Keep your hands warm poss buy heated handled saws
keep stuff sharp
correct chain tension
saws sharpened properly with cutters even length
replace sprockets
maintain your kit
cheers guys a few mixed responses there, thats what good about this forum you genuinely get great advice.
ive had a HAV,s test done and im ok but i was gonna try them anyway ( probably go for the timberlands) you are spot on bob about maintaining the gear the blower is an old hand held stihl so i will replace that soon.
cheers
