Warn 8274
Hi tree on just a stander motor and wire rope that's what mate run 8274 then there going for red hand built job from now they say is the best winch out there but 8274 very good winch thanks Jon
  • Replies 25
You can "juce" the 8274 up but the stock version is just fine for me
I've got a Husky 10 with plasma rope, linked to twin batteries with split charge system. Pros: pulls everything, can winch without engine running if needed - can't do that with either a PTO or hydraulic winch on a defender.ImageUploadedByArbtalk1402556974.643161.jpg.3ea3eeb83808eb64800b727a0ffddaae.jpg. Matt
Sent from my iPad protected by bombproof Lifeproof Case
I've got a Husky 10 with plasma rope, linked to twin batteries with split charge system. Pros: pulls everything, can winch without engine running if needed - can't do that with either a PTO or hydraulic winch on a defender.[ATTACH]158911[/ATTACH]. Matt
Hi Matt what batteries are you running mate thanks Jon
Hi Jon, heavy duty leisure/marine batteries - but not Odessy reds (as Paul foley said it was a waste of money). Matt
Hi Matt PAUL FOLEY no.s his stuff I've talk to him and had stuff off him Matt do you run 2 leisure batteries or just one then just a large amp batterie say 1000amp cold start power do you run high out put alternator say 120amp plus thanks Matt Jon
Have to say 8274 are amazing winch but there not that powerful there fast I run two of them on my challange truck there grate but my 130 has a husky up front as it's got more grunt but slower if it's going to be occasional use I'd go for an electric as the unit is easy to fit and wire up than the macanicals of a pto
12 v winch you can pick up cheep & have it fitted up and running in 10 mins and a lot lighter
PTO winch are a lot dearer to buy & more involved to fit and a lot heaver
So it all depends on how much you want to spend really & how much you think your going to be useing it !!
