aside from the obvious hilarious jokes, is there an accepted way to climb a monkey puzzle tree ? someone has asked me to remove some deadwood. I could see anything to put a rope over.
travis
  • Replies 25
Gloves, ladders and poles or gloves and throw line or gloves and pay someone else to do it! Gloves!
ย
Sent from my GT-I9505 using Arbtalk mobile app
i used the end of a hi-ab to deadwood a monkey puzzle! prob not best practice but did avoid having to climb it.
good luck
thanks everybody, thats probably answered the question.
Rob, is there such a thing as pruning spikes? also the tree is has a tpo, would you still get away with spikes ?
Travis, I have sectional felled two to date, never pruned one, however do not use spikes on a tree that you do not intend to fell. Ladders or MEWP for access, positioning lanyard and climbing rope around the tree whilst in position, I usually use a webbing loop and revolver karabiner with climbing rope passed through it, hope this helps.
ย
ย
ย
3 Counties Tree Surgery (Lichfield)
ย
ย
Pruning spikes; rubber covered tips so they don't damage the cambium ;)
ย
ย
Sent using Arbtalk Mobile App
  • ย
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. ย
If you're just starting out and you need business, equipment, tech or training support you're in the right place. ย If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,ย ย then you're welcome too.
ร—
ร—
