Red Roo: RedTooth Stump Grinder Tooth Sharpening Demonstration:
This is the video I was on about when I was on phone to you last week dean.
Mr git this is the system I used to use on all my teeth if you get it sorted correctly you can get a set of teeth back to new in the time it takes to drink a mug of tea.
The most important bit is the correct size of grinding wheel, you have to match the diameter of the wheel to the concave of the tooth, I got mine made in the states and posted over for less money than I could find the correct one anywhere over here.
Hope that makes sense.
Don't even think of just using a standard 150 mm wheel it will destroy the correct shape of the tooth in seconds.
