Ocean Poly Vs Yale Blaze
Frank
  • Replies 26
Stick with it frank i had the same problem with it. Keep using it and after a bit of use it starts to bed and grip nice! I alternate between OP and Marlow boa............................Ive been recommended off here to try Roblon not used it yet but its on my shopping list............................theres always somthing else to buy in this game :bored::001_smile:
roblon is ok nice and soft but wears really quick try wasp its equally as soft really plyable and good grip when used as a vt stays and dresses good and as well fujicura supply it:001_smile:
The 10mm has driven me mad!! Like Drew, I just can't get it to grip consistantly... Must admit that I got fed up of trying fairly quickly as my climbing time is limited so it may need to bed in a bit more. I switched onto some Armor-Prus and straight away it was much more supple and grippy. Much better!
Is armour prus available in the uk yet?
Ditto above.
John / Rich, have you got the swivel problem where it seems to wind up tight like a spring, and when you go to untwist your lines it doesn't like it?
What's going on there then?
Frank has simply used a picture of a young Gary Oldman in his avatar. In a wig, obviously.
