A little side track. But what do you think of Iseki ride on Barry? I am interested in something like an SXG19 or maybe the smaller ones (3600 I think).
Sorry, I don't think I have ever laid hands on one. Would imagine that they are pretty good though, being Japaneesy.
Pretty good mower watch out for lack of greasing on the forward/rev pedal
shaft! There's a grease nipple underneath which many miss to grease this the wears the hole elongated and it will fail to neutralise properly and creep forward or backwards
The drive down to the wheels is via heavy duty chains which allow a large open bottomed grass chute into the box so unlikely to block
Build quality is in line with Kubota
Is it a chipper, is it a mower or another broken stump grinder who cares we'll fix it!
Trying to find the leak which is emptying the fuel tank on my husqvana 327 rj strimmer when left.
Had the tank off assuming the leak was at the bottom as no fuel left. Couldn't find it!
Common problem?
Dave
Common problem?
Have you checked the rubber grommet where the fuel pipes go into the tank. Theses can shrink, or crack!!
Dave
Sit on wiring colour protocol ?
Is there one or is
it different for each manufacturer ?
Also apparently there should be a rectifier diode on the red wire from the alternator??? Mine doesn't have one ' just a frayed end. Is it critical?Can it be bought aftermarket? What amp grade of wire to use?
Edited by mikerecike
