Wait and get a 661, the lower vibes and increased user comfort for me at least makes it a saw I'd happily ring up with all day. The 880 is a beast.
Or get a husky 395, not a saw I've used personally but is highly regarded.
HI MARC that could be 6 months time or more for a 661 thanks jon
  • Replies 52
385/390 is lighter than the 650/660, and much more comfortable to use IMO, 395 weighs about the same, whilst the 3120 and 880 are fairly hefty for more than minimal use
Sent using Arbtalk Mobile App
Would you buy something like that for "minimal use", they are around £1500 aren't they ? Mind you if I had that money lying round I'd probably buy one just to look at. :laugh1:
Because they're bloody heavy! And waving a long bar around puts a lot of strain on your arms. Plus a giant saw is worth it when you get something you need it for
Get a 660 with 25" and 36" bar, much more user friendly, will be used weekly rather than monthly/every other month like an 880 with 36"bar.
I've got a 461 that will happily run on a 25" bar although slower than the 660 obviously, so i'm really looking for a saw that will run on a 36" bar.
The thing is if i get 660 is it a whole lot more different than the 461? its only an extra 1hp?
I was thinking if i go to the 880 i will definately notice the difference and it can be left on a 36" all the time as i run a 20" and 25" on the 461 (which is the saw i use basically all the time)
880 on a 36" bar is around the £1100 mark
I'd get a 660, we barely ever break out the 880. Plus the chain is the same gauge/pitch as the 460, so you can share 20/25 inch bars + chains with both saws :)
in that case, get the 880
my 460 has a 25", and the 880 36", the 460 does the bulk of the work, and felling on spikes, 880 for big stems only (rarely in the tree) and milling. i wouldnt want a 660 on 36" full time
Go to the dealer. Simply pick up a 660 and then an 880. That will probably make up your mind on which you want to go with.
