Echo 8000
kentjames
Hi all
I have been given a 1986 Echo 8000, handy :biggrin:
Having stripped it down, ive managed to deep clean it and fix the carb problem and have it running sweet :thumbup1:
It requires a new chain as the current one has been graunched by poor sharpening technique.
A few oregon possibilities have come up:
72LGX081G - which i think is similar if not the same as the one on it
22LPX081G - which I run on other saws
OR
Do I up the size of the bar and chain combo to something around 30 - 32 inch and if so what chain?
Some pics to brighten up the post below
  • Replies 31
Hi,
I had to read that twice "given" thats lucky, however, I see the plaques are all in French & thus needs to return home without delay, please post it to me tout suite!
Well done for getting it going & it looks in good nick, I dont quite translate the bottom row of the plaque "duelle de l'équipe" - dual team ? two man operation perhaps?
N
Edited by NFG
That says l'ouie and I think it's something to do with do not use without hearing protection. The two bottom lines are joined up as "porte obligatoire d'une protection individuelle de l'ouie"
Edited by peatff
  • 5 weeks later...
The saw has developed a fuel leak, I eventually found where it was and isolated it to behind the handle mounting :confused1: So after taking it all apart i've found its this little rubber grommet which seems to be a blank for the fuel tank :confused1:
Anyone know if this is more than just a blank? If it isn't where might be best to source a replacement for it?
Thanks :thumbup1:
