water damage ?
Fifer13
Hi
new member here and my first post :001_smile: so hello all !
I recently got flooded out and my ryobi chainsaw was underwater for maybe half a day. I partially stripped it down, dried out and put back together. After a bit faffing new fuel/spark and some carb cleaner i got it to fire up and it now starts okay, quickly settling down to a steady idle. My question is this - should i be concerned about water ingress to main bearings and motor ? Will the bearings run dry or are the motor casings watertight ? Its a cheap chainsaw and i really don't want to tear it down (might not go back together again):confused1:
anyways - any advice most welcome
stu
Well all things being equal you'd strip it down and check but then you don't want to do that.
My notion would be that it can't be too bad or you'd have some water coming up through the transfers from the bottom end which would affect the spark and make it run badly so if it's running 100% it would be a fair assumption that most of the water is out.
You could maybe run a couple of tanks of petrol through it at double the normal oil ratio to re-establish a good coating on the main and big end bearings and see how it goes from there.
It will be fine, I have had a couple of outboards go for a swim, remove plug pull it over until no more water comes out.
Run it for a good bit get it nice and hot, spray with WD40 before you put it up on a shelf not on the floor:biggrin:
H-A
WD 40 is cr@p. I recently had the misfortune to try their 'contact cleaner' as the excellent Comma varient is sadly no longer made.
It's that good a solvent that it just smudged the writing on the whiteboard when I went to clean it.
Hiding behind the name. Just like Draper and Dewalt :lol:
