550 seized up today
shillo
If there is a split, the impulse is still there, weak but it's still there! As for the air leak, the mixture leans out, so the revs rise and the carb compensates by richening the mixture, hence the black plug! This continues until the limit on the carb is reached and the saw then seizes. The repair itself is straight forward, but the carb will need resetting as it will be very rich.
Now before anyone asks why the plug wasn't white, if the OP has left the screen in, or the saw has been used a fair bit between the initial repair and the seize, there may be an exhaust blockage that resulted in a seize from a now over-rich mixture, but I have seen over-carboned plugs that have leaned out, and unless you look hard, it looks completely black
Sent using Arbtalk Mobile App
  • Replies 51
If a gallon of fuel killed 2 saws, then the supplier of the petrol should potentially compensate you, after having sold poor quality fuel.
Have you spoken to Esso, and sent them a sample of the mix?
H-A
