  • Replies 24
The best iteration I have yet seen for a horizontal splitter was at the last APf.
An American built machine, with a single pusher plate centrally mounted, feeding 2 different splitter blade set-ups, 1 at each end.
1 had a horizontal blade mounted about 150mm above the base, this split large rings down into smaller chunks which could then be furthur reduced by the blade set up at the other end.
Very very slick in operation, breaking down mixed size rings or blocks.
And no lifting.
stuff fell off the ends into bulk bags.
marcus
Multitek Inc
The "Tempest" splitter
Though if I recall the one at the show was tractor PTO powered.
I remember the 2 "out trays" which were feeding into Jumbo bags.
Quite how it would fare in respect of CE marking is probably probmatical!
did that link work?, Yes it did!
This was the technique I liked, splitting the large ring down, into managable chunks, one slice at a time, without ever having to lift it, or the unsplit bits "escaping"
I cannot fault the operation, except to presume the splitter ram is foot controlled?
Which I understand is a no-no for ce marking.
Edited by difflock
