How much would it cost to build a new ms200t from parts?
I had a mess about one day pricing it up awhile ago and it was around £1000 + VAT for the parts.
I always thought it would be a good little project, get some of the parts painted custom colours, maybe see a mate with a CNC machine to fabricate a few blingy bits etc.
I'll never, ever get round to doing it though.:laugh1:
If you were to buy 100 of each part, to build 100 saws, would the price go down?
I like the idea of chainsaw bling, special laser cut bumper spikes, jap bars are the only readily available things that springs to mind.
It is a little odd that it has not happened in the chainsaw world, custom exhausts would be an easy one, carbon fibre covers, chrome bars, aluminium cnc bits to replace the plastic., high compression ported cylinder piston kits.
If you look what is available for scooters, race cranks, pistons, cylinders. A vast range of go faster bits.
Perhaps it is only just starting in the saw world.
H-A
H-A
Would bring a whole new meaning to bombing a tree out
Sent using Arbtalk Mobile App
Or you could start with an old saw, replace:
Crank
Cylinder and piston
Bearing and seals
Oil pump
Carb.
So you have an as new refurbished saw.
NOT!
You're forgetting about a new
Bar
Chain
Sprocket
Air filter
Handle bar with all its plastic components that work together with the wire components
AV rubbers
Oil cap
Gas cap
Oil pick up
Gas pick up hose and filter
And if you are unlucky enough to buy an old one that came of a dude like me you would probably need a complete new housing because the oil tank is leaking at it's seam in the bottom of the saw.
Just go for a new 201. With new I mean the new factory modified 201.
I will see if I can find the serial number from which you can shop.
Or just go for the Husqvarna 540.
My colleague used a factory modified new 201 with the serial number 177543232.
So if you can find one with a higher number you're probably better of with that one than with an overhauled 200.
