''Chuga chuga'' sound coming from navara front end?
YoGi_93
Ive fixed the previous problem with my truck only for a new one to arise! every time I turn the wheel even slightly theres a loud noise coming from the front end. Its a ''chuga chuga chuga'' sort of noise thats the best way to describe it. Sort of sounds like a helicopter. Its not the wheel bearings they were changed about 3 or 4 months ago. Ive got General grabber all terrains on there so their quite aggresive and apparently the tread towards the edge of them can wear un evenly causing this sort of sound. But id have thought it wouldnt have come about this suddenly. Any ideas?
Possible power steering pump, anything bearing or drive shaft wise, shouldn't impact if the steering is moved only slightly.
I would expect it to not be so obvious when moving.
I do warn you that I know cock all about 4x4s though:blushing:
Is it at standstill or moving....slow/fast???
I'd go with pump too, mine loses a bit of ps fluid and makes similar noise when runs low
Sent using Arbtalk Mobile App
