my tip is DON'T DRINK THE WATER :lol:
I havent got a meter but if I want to know I weigh a log then stick it in the oven, it creates a nice smell, and after a couple of days you can weigh it again and work out the %
That would only work if you got the mc down to 0%.
  • Replies 61
I found even the cheapest meter better than guessing. I have had wood that I swore was bone dry burn badly on my stove then confirmed by meter its 30%. I found even different trees of the same species take different times to season could be time of year or next to river etc. Oak and Ash are the worst. Beech 3 weeks in the sun and its 20%
Good point there Steve.
Your metre sounds ok mark. It wont read properly in a bucket of water because its calibrated to work with the wood fibres. My skirting boards are 11- 14% My mate has a stihl one and we compare now and then both are roughly the same and never let us down.
being a bit anally retentive I get the log out and weigh it quite often, then put the numbers in a spreadsheet, so after a bit you can see where its going to land up.
Actually mostly I am worried about woodchip which is by definition 0% after 24hrs (at 110 C)
but it would be a useful comparison to measure a log then test it in the oven. The gadgets to measure chip moisture % cost nearly a grand, so its cheaper to get more wood.
It can certainly tell the difference between wet and dry timber, even if the figures are a bit screwy.
Would you recommend pushing the prongs all the way in for a truer reading?
Surely it works on resistance so this is bound to make any readings much higher?
You can do much the same quicker with a microwave, you get to a plateau just before the vinegary smell that indicates the onset of pyrolysing. A 20 gram sample takes a few minutes on a defrost cycle.
The moisture meters depend on salts to be dissociated as ions in the moisture to conduct current and the moisture is calculated from the resistance. I think some of the grain moisture meters used the dielectric effect. Pure water is not a conductor.
