Well done on the recovery, £15k :vroam:, guess lucky to at least be near a road, just imagine if it had been up on moorland or something.
Flipping scumbags though.
Trying to remember it like this helps.
Eddie.
How did you lift the front end for loading? Power pack?
Front end was high enough after Westtech and top quick hitch was removed for recovery, the Liebherr fitter lowered it down off a test point and used a pull lift to bring the dipper in.
Between the Mansfield Team and the absolutely brilliant fitter from Liebherr, all was recovered with no additional damage into the Liebherr yard to await inspection by the loss adjuster.
All I can do is await the decision now.
Eddie.
very sorry to see your machine like that hope you get it sorted. got the grab and rotator all fitted to the digger works well thank you .hope to see you working again soon
That is shocking! Must be devastating.
If only this type of person could get caught...
I'd like to see them caught in that Westtech to be honest!
Eddie.
Eddie.
did they pull the sun gears out the final drives or did they just drag it thats a fairly heavy machine for a winch what is it about 25t with all the gear. was it a security turf war or just vandals
