That's lovely James :thumbup:
Just been working on the chopping block again. Hope the pictures tell the story. The black marks are because the saw blade is a bit blunt. Something you get away with on softer woods but cross cutting maple shows this up. Hope it does not go too deep or else I will have a lot of planning to do.
  • Replies 38
[attach]139753[/attach]
That's what we use our 1942 butchers cleaver for.
I had to go look in the cupboard then, ours is just like that :thumbup1: My dad used to use it to cut the allotment pig up.
We have a recycled rubber wood chopping board about 1.5" thick, really nice looking thing and better to use than a nylon one, it doesn't skid across the worktop.
Just done the cleaning up and shaping. The reason for the chamfer is that the block is going to be mounted on a granite work top covering a hole where an old hob has been removed. The client did not want it to stick up too much and I did want to make it too thin as I thought it would be too unstable so the compromise was to make it a bit thicker than they want and the chamfer helps it look thinner than it is. No finish yet but probably going to use sunflower oil but may use Tung oil.
nice looking block beau.
has that been put through a sanding machine or did you do it by hand?
Hand planed then a quick go over with the random orbit sander.
Thanks bobh :thumbup:
