  • Replies 50
Ok .Mine does not . Its a Burley Hollywell 5KW but I am sure it punts out alot more . seems to heat the whole house , even the loft ....
Loft space would normally be insulated from rest of house and therefore should be cold, is there a reason yours gets warm Stubby?
Yep I sleep up there :001_smile:
Well I suppose that's a good enough reason!😃
Kitchen where stove is gets too hot, but it doesn't travel through house too well, but it does run 11 rads.
Thanks for the posts gents. Here's my little 5kw euroheat. When the heat gets so unbearable in the front room we open the door and heats most of down stairs aided by the open fire in the dinning room. borrowed the thermal image Camara from the station on Saturday and log burner was showing 215 degrees C. Toasty. ImageUploadedByArbtalk1382033391.053287.jpg.267589565458e93221557d9b48fcc918.jpg
Thanks for the posts gents. Here's my little 5kw euroheat. When the heat gets so unbearable in the front room we open the door and heats most of down stairs aided by the open fire in the dinning room. borrowed the thermal image Camara from the station on Saturday and log burner was showing 215 degrees C. Toasty. [ATTACH]137828[/ATTACH][ATTACH]137829[/ATTACH]
Nice looking floor there
Sent using My c
Cheers, was a swine to sand covered in Lino adhesive when we brought the house. Pure sacrilege covering the original pine boards.
Lino feck sake man some people have no class!:)
Sent using My c
