Lidl chainsaw grinder £20
Dave NE
  • Replies 26
the lidl grinder is a cracking bit of kit!, a little time spent setting it up and "tweaking" it and it'll churn out perfect chains all day, the only fault I've found is the led is crap, a good machine light(borowed from the lathe) cured this, and half an hour at the end of a day milling and all my chains are all identical again, makes a big difference in the quality of finish on the boards
I almost wet myself watching that video when the guy said "another special feature is" and it was the on off switch haha
Sent using Arbtalk Mobile App
Watch the video again here. What he is pointing out is that the grinder has a no volt release switch so it doesn't restart if you unplug it while switched on and then restart by accident.
I no that, it was just the way it was filmed,
