The last time I needed to buy strimmer cable the choices were very limited. Standard round or some square with ali powdered in it.
Now there seems to be a plethora of plastic types, more profiles than you can shake a stick at (star, square, round, lumpy, twisty ect) & some made with an outer & inner core both made of different plastics with differing properties.
So what do you all use?
Cheap & cheerful & lots of it or better quality & it lasts longer?
If it makes any difference it will be for mixed use, grass, weeds, brambles on rough ground & neat grass around mown lawn edges & trees / plants.
  • Replies 49
i use oregen a dark red one 3,5ml lasts a long time and cuts through anything. tried the yellow did not last long. tried a new one with wire in just broke.
will stick to the dark red one it works for me
Thicker cable for bramble and thicker grasses 2.4 or 3 mm on the lawn for edging up and especially round trees I use 2mm and a lighter strimmer any area of size I stick my rough cut mower on ,lot quicker and can still walk to local later!
What's your strimmer, I know my 343 will destroy most things with 3/3.5 line
Sent using Arbtalk Mobile App
Husqvarna 545rx .
Husqvarna 545rx .
Took out a tree stake today with mine, wasn't expecting that much damage, now have a swollen leg where it flung a stick at me
