Saw choice
Treemoose
  • Replies 29
Yep I was coppicing winter 11/12 and it was ffffffffreezing didn't do any coppice this year due to illness but one I'm back in the saddle I shall be investing. Also looking into a ms 150t as where I coppice I usually have to lift the oaks on the headland so the combines can get under them. At 2.6kg it seems the way forward as I am a lot weaker than I was before getting ill. This is assuming I can handle climbing again.
  • 4 weeks later...
What made you choose the 576 over the 372? Autotune?
Sent using Arbtalk Mobile App
Vibes are lower on the spec not as low as the 441 tho. I've suffered with bad trigger finger and try not to get it back. Yes I'm interested in the autotune see how it goes. Reading through other threads I liked what I was reading. Other than that its a punt.
You can only take other people's opinions so far (which I do appreciate) until you find out for yourself :001_smile: I try to move with the times and I know the 372 is tried and tested but I still like to try out the newer stuff
Hopefully a 20" will work out well :biggrin:
It will, I bought the 18 for a mill but use it alot for rigging up or chogging down, I have full chisel chains and have the rakers low on the 18,
If its anything like the 046/460, then the 461.Monster of a saw.I love my 046, and cant see myself replacing it with newer kit.I have 18",25" and 28" bars for it and see it as my `go to` saw for most occasions.Great power to weight ratio saw which i will use for most tasks with the right bar.
