  • Replies 46
The temperatures at the base of the liner must get very high, at a guess I would say a controlled burn of tar wouldn,t be as high a temperature. If it was left with no air restriction, I would imagine the temperature would rocket, if you have ever heard a full on unrestricted burn, it is quite scarey, it sounds like a planes turbine engine winding up
When I was in the fire service. We used to use a stirup pump with a hose on so only used the bear minimal water to put the fire out.
You put the pumpkin a bucket of water and sent the 360 degree spray head up the chimney giving the pump a few strokes every so meters.
Check chimney breast with thermal image camera.
It was not too messy a job unless it all started going pear shaped.
This was how they put mine out in about 1975, as you say not much mess
  • 3 weeks later...
I was told an old time method of extinguishing chimney fires today by a retired scientist.
Throw a large handful of salt on the fire.......apparently it robs all the oxygen ??
Will have to give this a go next time
Ahaaaaaa
Granny always had a pot of salt on the mantle, I always did wonder why, makes sense now
