Your right they are part of stihl. I work one of there mowers and it has worked hard for a living but still got a few seasons left in it yet but if money were no object I would get a Honda
which viking do you run??
lawnflite is basically a cheaper honda.
the mower is for domestic gardens and for block of flats grounds maintenance
i'm liking the viking because its weight is lighter, lawnflite comes in at 65kg
  • Replies 30
Honda pro roller 536 all the way!
2nd that, the only weak point seems to be the gear box but thats a fairly easy fix.
lawnflite danarm kaaz pros they use the old style honda deck. I dont think honda uses them any more
Having owned/used both honda pro and lawnflite pro we use the cheaper lawnflite pro now just because its a few 100 pound cheaper than a honda. they last just as long and cut just as well
not used a viking but from what i have seen they run Briggs and Stratton engines which arent for me
heres the cheapest i have found for the lawnflite pro
Lawnflite Pro 21" cut 553HRS self propelled roller rotary mower | F R Jones and Son
Of the two:
MB 655 VR - 21" self-propelled, Vario-Drive petrol mower with ReadyStart and rear roller
vs
Lawnflite | Everything you need for a perfect garden > Home > Lawnmowers 2012 Models > Lawnflite Pro 53cm/21" 5.5hp Honda powered Self Propelled Superior Roller Lawn Mower
The Lawnflite PRO is the one to go for.
I would consider myself more than time served on these machines and as much as I like Viking (esp 7 series) the LF pro is the best rear roller machine out there; only a kawasaki engine would make it better. The Hayter is not in the same league. The Hondas are v similar and as above the Kaaz/danarm/sarp/asuka/LFpro chassis is the old honda deck; honda shouldn't have sold the rights to it!
Edited by TimberCutterDartmoor
Think it's a 448 or along that line. It's not a top of the range one as things were tight when I had to buy it but it's worked hard and earnt plenty of money
