Does anybody know anything about Clarkes woodburners? Are they anygood?
Im looking for a woodbuirner on a budget of around £300 - £350...6ish kw. Any reccommendations please.
Cheers.
  • Replies 40
Cheers.
HI SEAN your better off with a good sec hand morso mate but then thats what think all the best with it jon :thumbup:
300-350 is a cheap chinese stove. Average life 3-5 years.
A Morso has a life of over 30 years, more if you look after it. If you can find one then a used one at perhaps £500 is a good buy, you should have no problem getting any spares if a bit of TLC is needed but make sure they are genuine ones as there have been some chinese parts to fit Morso's coming in, mainly top baffle plates. There is a member here that reconditions and sells used Morso's, he will I am sure comment in due course and may well be able to help.
I would recommend a better quality used stove but do appreciate things are tight. Cheaper stoves, then look at Carron, their 4.7kw stove is basic but well made at yours for about £500.
If you are not in a hurry sometimes used bargins can be found on e bay etc during the summer, no bargins this time of year though.
A
There are bargains any time of year if you look properly , eBay , freeads , gumtree , local rag , I picked a stunning arrow multifuel burner just before Christmas for £210 I'm well chuffed , as they have said buy a good quality 2nd hand instead , good luck .
Cheers.
False economy; poor build, poor heat output, eat wood :thumbdown:
Just completely abandon your cheap woodburner idea and concentrate on quality. Or as above - good used.
Cheers.
Don't wast your hard earned wonga ! Save a bit more and go for one of the new more efficient stoves . I have a Burley at 98% efficiency but there are other makes that are similar .
Like this :001_rolleyes:
