wood chipper- grade of chippings
TheTechnobear
hi,
Ive got a JoBeau M300H which im generally very happy with, and is serving me well, im using it to chip almond tree cuttings (so hardwood)
but have a couple of questions I wonder if anyone can help me with...
(not sure if its a specific to jo beau or not really)
a) the output chips, are quite large (1-2cm), and it sometimes throws whole twigs through (i.e. unshredded), though only when small diameter (say 3mm ish)
Ideally, id like to get these down to a smaller size, and with no twigs....
(so chips could be fed into a pellet burner)
is it possible to adjust the chipper, or do i need to process with another machine? if so do you have any recommendations?
b) I have new blades on the machine, but would like to get some spares...
are there any recommendations? in particular to deal with almond wood given its so hard
thanks for any thoughts and suggestions
Mark
As said its feeding too fast. The faster it goes the more wood gets put between the blades. Bit like dicing a carrot. The faster you move along it the bigger the slices. The while twigs will either the feed in speed or the anvil is too far away from the blades allowing twigs to fold and get pushed down between the blade and anvil rather than being chipped.
How does a gravity fed machine feed too fast? Gravity is a constant.
The problem is with the gap between the blade and anvil
thanks for such quick responses, good to hear that it sounds like i could be getting better chips out of it directly.
I will check the gap of the anvil - I did not realise it was adjustable, probably because the manual is in Spanish, and my Spanish is not too hot at present. Will try to work it out/find a copy of the manual in English.
Feed to fast....
okay, being a bit dumb here... isnt the feed controller by the throttle of the motor? i.e run fast, the drum is rotated quicker = faster feed, or is it not that simple?
Im usually run the engine at around 2/3 throttle (its honda 13hp engine) and crank it up, if needed due to thicker branches.
Slightly concerned if I slow it down, it will snag due to hardness of wood, as I assume a certain speed/power was needed for cutting.
fyi, the almond branches are on average 2-5cm diameter on the main branch, but obviously i still have attached the rest of the 'pruning', so theres a fair amount of 5mm or so twigs attached still
thanks again for the help
Edited by TheTechnobear
