DDRT or SRT?
48 members have voted
  1. 1. DDRT or SRT?
    • do you SRT to DDRT anchor, then work.
      6
    • SRT for entire job
      9
    • you use SRT because it's easier/less complex
      3
    • never use SRT
      25
    • tried SRT but chose not to use it
      5
As long as your in a tree and working safe it all good. I SRT for 90% these days probably 10% DRT. I find SRT much faster, efficient and better friction management for myself. Horses for courses really but i guess you really have to have given both a good bash to have a fair opinion.
  • Replies 74
Very small trees - I bodythrust (Ddrt)
Small trees - I use a pantin (Ddrt)
Medium trees - I footlock ... badly (Ddrt)
Anything bigger I use an SRT access line then switch over to Ddrt :001_smile:
Mostly i send up a running bowline, srt up, advance DdRT and then depending on the tree and the type of job I work the tree DdRT or SRWP. Leaning towards SRWP for everything at the moment.
If line is just over a fork its not static as it can move, if it's alpined at the rope to cinch it to a limb only one leg is static. If both legs are tied off so both are static it's drt confusing when it comes to footlocking really.
Sent from my GT-I9300T using Tapatalk 2
I stand corrected mr murray, quite an in-depth look at it :thumbup:
Depends on the situation for me.
Srt on larger tree access, then Ddrt for some situations.
Then normally Ddrt into my tip if I don't get a good wp line in from the ground after srt to as high as I can get. (which is quite alot as i'm snakes at throw lining) Then make chose as to srwp or Ddrt for working the tree.
