has anyone owned or used one of these? its a early 90's ex MOD truck.
i was looking to get a forestry trailer with crane but my tractor is only a ford 3910 so i would need to replace that also with a larger 4x4, thought this might be a better plan as it would travel at a sensible speed on the road.
  • Replies 49
Yer they have at last the EA need to sort out the ditches out ASAP! The drains need sorting as well! It's got worse since glen (timbers) put that pipe in there ditch
I'm sure max payload is just over 4 ton so by the time a decent crane is added, this would be down to around 3 which doesn't give you much capacity. Initially I thought the price was high as you can pick up a good ex mod truck for around three grand but obviously the crane and winch and the fact it is all ready road registered add value.
We looked at similar for moving timber around the yard and extracting from woodlands and decided forwarding trailer and crane was more sensible - larger capacity and no problems registering.
