Would you be interested in selling large value bags of kindling
18 members have voted
  1. 1. Would you be interested in selling large value bags of kindling
    • No offering people a choice confuses and they often buy nothing
    • Yes alot more people are looking for value
    • No we tried ugly kindling before and it did not sell
    • No it cost more to transport and store
We make alot of nice neat bags at the moment but are getting offered more timber that is just a tad too short or too notty. This can cause problems in the kindlet. I have had an idea to offer a value bag at the same price but increase the size to compensate for the untidy look of the kindling. How much bigger would the bags need to be ?
  • Replies 20
Is 25 or 50% realistic? As a consumer rather than a producer I can see that people could be put off by a slight redcution in convenience but if you're up front about the lower quality a significantly bigger bag would win most people over.
Kindling that is bone dry can be any shape you want . If there is a bit more for the same money it will sell I am sure . I would buy the bigger bag if I had to buy some anyway .
I'd just add that stacking of the more irregular stuff is likely to result in more air than the bag with regular specimens. The top image seems to be a fair compromise.
You obviously get enough people wanting kindling, I just split a log with my trusted axe, works every time.
The bags are currently 450mmx500mm and weigh 4-5kg I am thinking bigger bags would be 450x800 and weigh 6-7kg so a serious bag of kindling. The trick is to supply a different market without upsetting our customers excisting stock. Thanks for all your feedback.
Depends how much dearer per kg the kindling is compared to firewood price?
The only downside that I can see is weight for weight one will light fewer fires with the larger pieces, but the larger chunks will contribute better to the heat output.
But "expensive" fuel.
I would suspect (but purely "gut" feeling ) that 50% extra weight for the same money would get you sales.
Though the extra bulk and untidyness (vis-a-vis storage) is a consideration which only the consumer can make judgment on.
I simply light the stove with the finer rubbish from the pile, incl what would be considered logs (weight wise) as long as they are splintery or have a high surface area.
They would definately be a lot bigger/coarser than your sample as above.
For the boiler outside I throw back the nice(er) straight(er) bits and split them with an axe for the next nights lighting while the boiler gets up to temp.
Cheers
Marcus
