I've got 25 tonnes of Atlas Cedar stacked in my yard from one tree. Ideally I'd ;ike to try and sell it but have no idea where to start trying to value it. I'll attach a couple of pictures, but the main stem weighs 5 tonnes and is nearly 5 feet across, the other bits are on the whole pretty staright and range from about 18 inches to three feet across.
It seems too good for firewood but is there a market for timber such as this?
The trunk might be of value to some furniture makers. It is sometimes used as the back panels in cabinets or as draw bases as it gives off a good smell. The limbs might be of use to wobod turners too. So would probly be worth a phone call or two around.
Tried a number of times over the years to find an alternative to just selling it for logs and failed, I find the mills to be a waste of time but on the plus side the customers that have had it for logs always ask for it again.
Like all timber it's a shame but your easiest route is firewood...
Cedar of Lebanon is easier to sell as that's the favoured one for wardrobe backs but there is a big knot in the back of that main stem which de values the timber for proper makers.
No sawmills will be interested....
You could see if there's anyone with a portable mill or chainsaw mill nearby - offer to go halves on the timber you produce.... this will make great outdoor tables... durable and easy to work.
If you have some curved pieces there (it looks like you do) and can mill them yourself I know a framer who loves these and usually pays around £16-00 to £20-00 a cube for thick pieces i.e. just mill the middle 8" out. PM me if you want his number.
Try visiting your local arts and crafts store and see if you can purchase battery powered clock works and clock face. I have used Southern Red Cedar here state side to make clocks. Cut the logs into 2 or 3" slabs and run them through a planer. Determin the center of each slab and drill your pilot hole. Rout out the backside of the slab and install the clock works and affix the numbers to the face side. I have put a coat of varnish or polyurethane over the face of these types of clocks and they make great gifts or sale items. All the best.
easy-lift guy
Cedar is used to make beehives so may be worth you looking at suppliers of these such as thornes or maisemoores there are lots of others about as well.
Is atlas ceder worth any thing apart from fire wood , I was always under the impression it's a bit like turkey oak to english oak in its comparison to ceder of Lebanon.
I have thought about it a few times but just seemed really brittle.
