How hot does a woodchip pile get and what can you cook in it?
Apart from heating water/cooking something slowly, is there a way of converting the energy in a woodchip pile into anything?
  • Replies 20
I was told by a friend that houses in Finland had been built with a bunker for chip to heat water,sorry to be so vague but can't tell you any more,it was a long time ago.I would like to know more about this myself,fantastic idea if it actually works.
A contractor mate looked into this as a heat source to raise water temp. for his imported Koi. If the temp stays up over the winter they continue to grow.
Problem was the chip cools if it doesn't get agitated. Maybe the conditions get anaerobic and the decomposition slows. Put a jar of water into a chip pile one morning and it was almost too hot to touch by the end of the day.
Sorry but that hasn't answered your question!
I've put a water pipe in mine when i last moved it. Its surprising how hot it gets. Going to use the heat to warm the workshop. I hear that a thick layer in a polly tunnel with a good layer of soil is good for growing soft veg in winter
I was going to say that but didnt want to tell every one. Under floor heating just like in houses or a couple of radiators placed in middle of your log pile. Under floor would be best as heat rises
I looked into this years ago and was advised that if you run pipework through the pile, you are removing the heat which will make the microbe action less efficient, unless you can have a slow constantly renewing process.
I would imagine the only way to extract heat efficiently without affecting the microbes would be to have it enclosed and extract the heat given off by the pile from above it ??
