I still can't find a system that works for me. I've tried a hitch climber with both VT and a distel but whatever hitch cord I use it always seems to bite off. either when I descend then stop or when I'm pulling slack in. so I tried a Prussic which works but obviously it doesn't self tend and still bites off when I descend them stop. My rope is 13mm it's a big bulky thing but I have no other choice in the matter because my boss doesn't let us use our own equipment. I'd invest in a spider jack if we could use our own gear but hey ho.
  • Replies 24
How much tinkering have you done with the VT?
I mean, how many variations of wraps and braids have you tried?
My experience is that (depending upon the wraps/braids) a VT's range can go from 'never moving' to 'trouser soup', even on a thick rope.
I haven't done loads of tinkering with the vt To be honest I didn't think it would make a massive amount of difference. I think I could do with a thinner rope I agree. At the minute I'm messing around with 10mm ocean polyester and 13mm main line. I have also tried 8mm friction cord.
Ive been using 13mm marlow gecko with 10mm marlow boa as friction cord and works well, I dont think thinner is always better.bought some 10mm OP and having hell trying to make it work with my hitch climber. Going to end up turning it into a prussik loop if it doesnt start working soon
It could make ALL the the difference, and you seem motivated enough to be seeking a good set-up.
Try reducing the number of wraps and possibly increasing the braids and see what happens. Even a twist in one of the hitch rope's legs can make a difference.
Remember the 'grip' of the hitch is always a compromise between secure locking under any circumstance (but accompanying resistance) and easy self-tending (which might miss an immediate grip).
The 10mm/13mm combination should be fine if the hitch is fiddled with.
Give it a try with the gear you've got before spending money on new stuff.
I use 3 wraps 3 braids and it doesn't always grab but I check it everytime so it's never been a problem and I like that it doesn't grip really tightly
