I have previously used windscreen bond (the black stuff that pant glass is stuck in with). It remains semi-flexible (prevents vibration being transmitted to glass) and is impossible to remove. Make sure everything is clean and dry first and the bonding agent must be applied hot (or you won't even get it out of the tube). Keep pressure on for a good few hours and it will be there forever.
I have only ever used this on the 'wagon sheets' of old though.
I found some stuff called vinylweld which I have used to good effect on the seat of the quad after some divvy had a reel of barbed wire riding pillion. I think that wagon tarps are pvc so a solvent cement would do the job but you need a patch to stick over the hole.
This stuff will stick just about anything to anything. Its Polyurathane and is used to stick body panels to cars.
It is petrol resistant and will repair holes and splits in fuel tanks, and is ideal for blobbing onto a damaged plug cap to avoid those elbow shocks. I would never be without it
