Stumped for an idea of what to do with this
EddieJ
It is approx 2,100mm long/tall x 590mm at the lower stem section x 1,100mm at the tip Y section.
I just can't come up with an idea for it. I'm tempted to run it through length ways, and use it for garden furniture, but the rot inside could turn out to be a disaster.
Any ideas, good or bad welcome.
I'd plank it into 2" as I'm sure a few planks would come out ok - the top part is a good size for a coffee table and the grain should go round in a circle which'll make it unusual....
I know you could make a large carving but then the hole becomes more a hole that you could've chainsawed out anyway...
Just me pennys worth
:biggrin:
Thanks for the replies.:001_smile:
:biggrin:
That was exactly my thoughts as well. You can make a hole in any piece of wood, but finding a naturally moulded example is not quite so easy.
I struggle to visualise things such as this, but one thing that I have learnt in my limited period of playing with wood rather than just working with it, is that you can't beat the natural beauty that is already presented to you by nature, and that you should work with it, and not against it.
I'm now wondering how it would look cross cut just below the main arms, then strip the bark off, sand blast it, and use it as a base for a glass table.
Obviously you would need some stainless adjustable supports, but it could make a lovely table base and talking point.
Something will present itself when least expected.:001_smile:
I think that would look cool :thumbup1:
