  • Replies 22
the farmer wanted in the top field and it was leaning the wrong way so we tried a bottle jack did the job,
Nice job :thumbup1:
One thing i found out in the couple of fells ive done with a bottle jack the jack goes into the wood it needs a bigger wider plate welded on the top to spread the force of the jack to stop it punching through the wood
Nice job.
I've done lots of bottle jack fells and makes it so much easier. As already said you want to back up with wedges and have either a wedge or a steel plate on top of the jack or they tend to dig into the wood.
I'd of put the jack in the stump though rather than cutting a notch in the timber.
Nice job.
there was barbed wire lower down so we went abit higher and cut into the top half instead,i know what you been brush cutter
