where to get cheap hydraulic oil
littlerob
my friend is looking to buy some hydraulic to renew for his digger 3 lorry mounted cranes a loading shovel and his mini tele handler and tractor he is looking to buy about 20 gallon so where ans what cost do you get yours from
HI ROB they days are long gone re cheap oil I've just put 13lt in tractor o well jon :thumbup:
Give H.A.S a try in Bury-St-Edmunds, i use them all the time, best price i can find.
Your all missing the point. If he has that many machines to renew then he will need A LOT. As the OP says, 20 gallon not 20 litres! If he's lucky they will all run HV46, and he can just get a good price on a barrel of that. However, be careful with the tractor as they will usually use 'back end oil' to do the transmission and hydraulics, and HV here is a no no.
