A new age in chainsaw milling dawns with the Granberg Flip and Rip
sorry to burst everyones bubble, but this type of rail csm has been on the go in the usa for years now, if you look on you tube youll find dozens of versions of the designfrom tiny little portable ones to monsters using large 4stroke engines to drive them, the BIG question is just how portable is granbergs design, and how long does it take to set up on site, does it produce boards any quicker, or better than any of the saw benches, or mills on the market at the moment. I will watch this one develop with interest as I myself mill some big logs,
  • Replies 44
When you get a sec Stevie can you put some pics up of your double milling set up? There's not many like that about.
:biggrin:
No probs, we have only had a days playing with it, milling work is scheduled for after October.
No bubbles burst - Granberg have been making CSMs in the US for 40 years (need to confirm exact date) - there is nothing like this available.
There are loads of other versions of CSM using a frame in the US (there's even one here in the UK) - but these are mainly home made jobs - I don't know of many that are accessible and on the market.
However all tend towards a fully static set up using heavy angle iron. They are not portable and use only a large chainsaw for all out slabbing.
The way the saw flips from horizontal to vertical is unique and also this model is now close to being a production model. It's easy to build something that works, much harder to build something that you can then make easily.
:001_smile:
as I said Rob, I will be watching this one with great interest, portability, and ease of setup being paramount as a great deal of where I mill isnt the most accesable of sites, a combination of M7 and big mill means i can get most places, but I am always looking for a "better" setup, so much so that I am in the process of building my own bandmill, biased towards the ability to get it into places that would prove impossible for whats out there at the moment.
  • 3 months later...
"bump"
Rob,
Any furthur developments on this rip and flip mill being sold commercially?
Any notion yet of disposing of your first prototype model?
An M8 Logosol still beckons otherwise.
Or a wee woodmizer.
Or sommat.
Cheers
Marcus
Bump again.
I just realized:blushing: this Granberg "flip and Rip" is essentially a bandsaw mill set up............ except using a chainsaw as the cutter instead of the bandsaw.
Am I correct in understanding that the potential problems with a narrow blade bandsaw mill are most likely to be due to the "band" wandering due to poor sharpening, incorrect tension, undue forward pressure etc etc.
I presume the more rigid chainsaw bar is less susceptible to such deviations, especially if supported at the end of the bar as with the Grandberg.
(but optional on the Logosol?)
I always like to know the "why"
cheers (again)
M
No worrys!
I've been using the F-n-R for the last couple of months and all the basics are there but it still needs a little tweaking... small things like sawdust getting in the box which then stops you rotating the saw so you have to stop, undo screws and blow out... line adjustment on the horizontal needs re thought slightly... and a few more things...
It's all coming along but it's got to be right and although small things to fix it needs to be solid and robust as when it's raining and something is not working right is frustrating...
I have a bandsaw and have yet to cut any wood where the band wanders.... sharp blade and slow progress seems to cut straight as anything.... but I've not cut any tricky wood yet... !
But still a way off I'm afraid... one thing is I think it will be very easy to drop the mill onto an Alaskan and use that for large slabbing.
:biggrin:
  • 2 months later...
Hmmm... coming along slowly.... I've had a few problems with the lateral positioning so it may be the initial version is just for all out slabbing where you can fit your existing Alaskan into it....
The flipping through 90 degrees will come but in some ways getting that right is slowing things down a little...
Personally i think the frame the mill sits on still needs to be simplified...
So sorry - still nothing concrete to tell you :blushing:
