  • Replies 20
but their not:001_tt2:the rope is stopping you from falling not the spikes
Ok so when the spikes slip out on a smooth stem you don't fall or slip down at all . when you lean forward and flip the line up what's holding you in place supporting you the load ?
I know it's fairy dust, very expensive stuff :001_tt2:
So why use spikes!
Anything supporting a load in the workplace comes under LOLER
I think you mean equipment used in lifting or lowering operations in the workplace comes under LOLER
Not anything that supports a load :001_smile:
So why use spikes!
Spiking with just a flip line is no longer recommended as an access technique.
