  • Replies 122
I have got some Sugi nose fixing kits for the larger noses... These are £16-00+vat need to get them up on the website :blushing:
Or you can just use a punch to drift the rivet out - put the new nose and rivets in then flatten out.
I've used the chain breaker for this then ground the rivets flat.
that's pretty much how I was thinking I would do it,cheers rob
ps get them fixing kits up so we can get a look :biggrin:
I've got them for the large noses - you need a proper ungiving metal surface to use it but they seem to work well.
Getting x100 of both small and large kits for next Sugi order.
:biggrin:
  • 6 months later...
Hi Steve - the bars all came in on Monday and I spent the whole week lifting boxes.... there are going to be so many options that I need to sort through exactly what is what.
But the bars for the T540XP are now up there and listed (still have PRE - ORDER) in front of them - but they are there.
So fill your boots :biggrin: + you will get a good throw in.
12", 14" and 16" pro lam and light type.
Also have 1/4" bars but no one can seem to find a 1/4" sprocket for the T540XP!
:001_smile:
Rob do you have 15" .325 in for a 550??
Yes - again stick the 550XP in as an option and you have a large range of bars they're all .325
In fact there are loads of options now - you can have .325 .063 both in pro lam or light type so if you run Stihl and Husky saws you can stick with one chain type.
Also have 3/8 lo pro bars and 1/4 bars that will fit the 550 as well as a 20" Q tip bar... And the VH mount bars which will run 3/8" standard .058.
So a lot of choice and can't put these on the chainsawbars.co.uk website as it stands because will just lead to confusion so there will be a new website coming soon...
All the bars marked PRE ORDER are in stock.
:001_smile:
:001_smile:
Thanks Rob I'll head over and see what I can spend my penny's on.
