Experiences and techniques of using screw type log splitters.
I use a Hycrack screw type splitter. We bought it as most of our firewood is from stunted hedgerow trees who's grain sometimes goes every which way and I presume conventional splitters would struggle. Sometimes it works great but other times it is a pain and scares the hell out of me.
I am interested in others experiences i.e. how fast do you run it and have you found ways to make it safer (emergency cut off etc)
Cheers
found it loves seasoned wood best,, dangerous on small diameter stuff as it spins it,,and potential for trapped fingers, on the green wood it sometimes just drills a hole,,,i swapped to a vertical machine, and wouldnt go back,,,but some people swear by them,it really is a matter of what your splitting, there great on old big dry rings though,,,
Keep the wedge sharp and the tip might need replacement. Used them and done hundreds of tons with no problems. Small logs should be placed to one side to avoid the turning over issue.
Wish an electric version was made!
Edited by TRADITIONAL LOGGERS
more info
i love my screw type splitter great on the big rings
for green wood you have to give the splitting cone a tickle with a file to get it nice & sharp so it cuts in easier & dosent just drill a hole in the ring!
probably a good tip dave :thumbup1:
Yep I give the tip a light file form time to time and it does help. What revs do you guys run at? I have been running at 1500 rpm but it's proved surprisingly thirsty with our 55hp compact tractor.
HI WOOD we had one run at i think 1500rpm on a mf 165 so 65hp it was very good on dev it needs to be now as it 65p per lt we now a posch 20ton thats good on large stuff i no a mate run a screw type on a mf 35 but they will stall the engine on large knots thanks jon :thumbup:
Used mine for the last 15 years , run it with an old ferguson 65, never sharpend the wedge or tip and it splits anything i show it with ease, do tons each year. Never used a vertical splitter as the Hydraulics are to slow. Never squashed a finger yet as i never hold the logs around the sides but just push onto the cone until it bites then leave it to do the rest.
